does anyone here own a Howard model 99t
Hello everyone,
I picked up a howard model 99 chassis and I would like to build a Cabinet of my own design for it since it's a working chassis
this is a very good 9 tube with very strange tunning system .
I'm wondering if anyone here has one ofthese or knows where I can a photo of the Tombstone style model .
thats the style I'm planning to build using like some kinda figured wood veneer and maybe add a eye tube and 8 to 10in woofer .
Sincerely Rich
P.S. has anyone ever build a Tombstone style cabinet from Scratch
