Bought a 16B Now What?
I just bought a 16B from an online auction.  It looked to be in nice shape from the photos.  Cabinet is nice but the chassis is not.  Someone sprayed the chassis with gray paint over rusted areas, painted the tube shields, etc.  But, I think I can take care of that.  Also, the speaker is in good shape.  My immediate concern is the tuning assembly.
As you can see in the pictures, someone has tried to do some repair. I'm not sure how this thing works and have several questions for you experts:
1.  How many rubber wheels should there be?  I have the one rubber wheel and the rubber OD on the dial.
2.  What should each rubber wheel mate with?
3.  Am  I missing any parts?
4.  The left hand shaft is the actual tuning condenser.  The longer silver shaft in the middle of the picture is the tuning knob shaft.  The shaft with the rubber wheel doesn't appear to connect to anything and essentially free wheels.
5.  Does anyone sell repair parts?
6.  Has anyone out there repaired this mechanism and if so do you have any suggestions, lessons learned to share?
Joe Miller
See: http://www.philcoradio.com/phorum/showth...?tid=14970
Hi Joe,
Congratulations on acquiring a great radio!
AFAICT you're not missing any parts to the tuning mechanism.
You will need to replace the rubber on the drive wheels. This tech section article tells how to rebuild the dial drive on early model 16 and similar :
http://philcoradio.com/phorum/showthread.php?tid=14970
[Edit: I see Bob replied with the same link while I was replying  Icon_lol]
Here's a photo of the mechanism on my 16B (before repairing it):
And a close up from another 16B chassis:
The speaker table error?
Philco 70 antenna lead
There are currently 5907 online users. [Complete List]
» 1 Member(s) | 5906 Guest(s)
