16B chassis — questions
#46
I would probably just make my own by cutting a strip of metal from a tin can and bending it to shape, but a search of the web found these:
https://www.ebay.com/itm/NOS-vintage-Vac...ctupt=true
https://www.angela.com/ceramictopcapfor6...tubes.aspx
Hope this helps.
#47
Any tips, clues, do's don't's about cleaning the tuning condenser?
I have blasted it a few times with compressed air and contact cleaner, but is there a better way?
Thanks
#48
Don't blast it from above - the mica insulation in the four trimmer sections can easily be damaged this way...
#49
There is a whole thread on tuner cleaning here:
http://audiokarma.org/forums/index.php?t...og.144163/
A lot of it is repetition but you will get the idea after a couple of pages.
91H Code 126 Restore
There are currently 4068 online users. [Complete List]
» 1 Member(s) | 4067 Guest(s)
