Hickok Test of 1LC6 Wrong
Some probably know- I probably knew at one time:
The bias setting for the osc. section of this tube should be 10 rather than 30 like the pentode section. The built-in chart for the 533/534 is wrong. The on-line doc. is correct. Don't throw away any good ones since it is the osc. for one of the Zenith TO models (one that does not use the 1L6).
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5777 online users. [Complete List]
» 3 Member(s) | 5774 Guest(s)
