Echophone S-4 Help Wanted
Threads: 22
City: Meridian, ID
I have the set fully assembled, non-working, with a couple of issues impeding my progress.
[Image: https://farm8.staticflickr.com/7925/3288...940f_z.jpg]
The overriding issue is too-high voltage. At 115VAC, the plate voltage for the 245 is over 300v, and over 700v for the rectifier. So, I'm doing my testing now at 60v or 75v and all the other voltages seem higher than expected-- except the filament voltages, which are all good.
[Image: https://farm8.staticflickr.com/7902/3288...31fa_h.jpg]
(Direct link to image: https://flic.kr/p/S6JA4f)
Is the transformer putting out too much voltage, or is it likely that I have made some wiring mistake? I've checked all the wiring several times, and it all seems OK except I'm uncertain about the RF transformers, but I'll ask about that later.
Thanks for looking,
Henry
Threads: 72
City: Linn Creek, MO
Henry, make sure you are using the high voltage tap on the power transformer.
M R Radios C M Tubes
Threads: 22
City: Meridian, ID
Steve,
I had the line connected to lug 81, 115V on the schematic. I moved it to lug 82, 125V. Is that what you meant? At 115VAC, the 245 plate voltage was 345V. Here's a full description of the transformer outputs at 60VAC, extrapolated to 120VAC.
[Image: https://farm5.staticflickr.com/4819/3289...6ded_c.jpg]
Threads: 72
Yes, the line should connect to 80 and 82. If connected to 81 all voltages will increase about 10 percent.
Threads: 22
City: Meridian, ID
Hm-m-m. Voltages did indeed increase, but the problem is that the B voltage is already too high. The 245 plate should be some between 150v and 250v. It's 345v at normal line voltage. Except for filament voltages, a quick check seemed to show all other tube voltages were too high as well.
Threads: 112
City: Medford OR (OR what?)
Are you testing this unloaded, that is, with one or more tubes removed?
Threads: 22
City: Meridian, ID
First let me say that I finally realize how the high-low voltage taps work--that is by changing the ratio between the primary and secondary. Before I couldn't see how going to the high voltage tap would decrease the transformer output.
I am testing with all tubes in. Fully loaded. But my test results have been so inconsistent that I switched to a different multimeter. The meter didn't make any difference. What I can see now is that when power is first on (Again, at 60VAC) the 245 plate voltage rises from zero to about 135 volts in a few seconds, then slowly reduces to 107 over a period of 2-3 minutes. I'm keeping it on now for 20 minutes to be sure that it stays at 107. If that stays steady, I check again at 115VAC, and if I get the expected 210v at the plate, then I'll proceed with the rest of the voltage tests, and if the radio still doesn't talk, then I go to my next issue.
That y'all so much.
Threads: 22
City: Meridian, ID
Further testing of the 245 plate voltage is more confusing (I keep checking the 245 because they're expensive and I'm afraid of killing it.) At 60VAC, the plate voltage quickly rises to about 110, then over a few minutes it decreases. After 20 minutes it's down to 70v.
BUT, when I ran it at 115VAC, the plate voltage started at 220v and over time, it increased until I stopped at 400v.
After reviewing all the wiring again, including the speaker and speaker plug connections, the only thing I'm unsure of is my wiring for the antenna coils, RF coils, and the potentiometer. First question is, what kind of RF coils do I have. I've assumed that they're the original flavor--not the later models with Litz wire.
[Image: https://farm5.staticflickr.com/4880/3288...d84f_c.jpg]
Of course, I have no idea what the descriptions mean. With the connections I've made, here are the coil resistances. Does it make sense?
[Image: https://farm8.staticflickr.com/7883/3288...ce72_c.jpg]
One inconsistency is that I disconnected one of the Bakelite caps, and it isn't 50pF as indicated on the schematic. If my cap tester is right, then it's less than 10pF.
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Model 27-84 BUZZ?Humm?
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Philco 630csx power cord
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
On K2, pins 1&2 are shorted. On K4, Pins 1&3 are shorted. Others are OK. - your 0.047 caps are fried in both
Th...morzh — 10:40 PM |
Hello Tynwald ,
I would not use that plug and what I would do is us Some of this cloth covered wire !
you can also buy...radiorich — 10:28 PM |
The voltages are the same except #4....R3Sons — 09:29 PM |
Let's try to sort it out. So we are working with the same info here's the schematic I have:
...and here's the pin o...klondike98 — 09:03 PM |
There are currently 2932 online users. [Complete List] » 1 Member(s) | 2931 Guest(s)
