Video of my electrically restored 1952 Motorola 52X
I left the cosmetic's alone because that is not my department.  Icon_lol This one took considerable work to make it live again replaced all the caps and resistors along with a 12BD6 tube, speaker, power switch and rubber tuning capacitor grommets no silver mica disease here.
Sorry for the lack of tuning because there is not a great selection in the day time. Strange it uses a 12BD6 in place of the 12BA6.
https://www.youtube.com/watch?v=6s9s-lSIwQs
sound is pretty good!!!
Nice!
Like the funky tuning indicator on the top. WSM Icon_thumbup
I have tried to pick up WSM up in Boston only to shut out all the time, used differing antenna, different sets, etc........
Enjoy.
"Strange it uses a 12BD6 in place of the 12BA6."
You're like me, . . . you got used to seeing the same 5 in the All-American-5 plastics tabletops, ( I could recite them by memory by the time I was 13), . . . then got bent out of shape when you discovered they weren't the original 5 !   Icon_crazy
Nice work bud.
I also like the odd tuning indicator, sounds good Jake...
There are currently 8625 online users. [Complete List]
» 3 Member(s) | 8622 Guest(s)
