Threads: 337
City: lawrenceville nj
hey guys and Brenda
any one have ramsey am25 ?
I bought it used said very low volume and distorted
works but I can only get 500 very end of dial on 39-116 and little distorted
like I need a hair more adjustment I tied trimmers only one made it louder r31
http://sourcefmtransmitter.com/ramsey-el...manual.pdf
thanks sam
Threads: 268
Hi Sam
That set isn't tuneable per say, there isn't a tuned circuit to adjust the frequency. It does have a crystal that is used for a time base and that's what it use to determine the output frequency. What you can try is solder a small value cap (like 5-20pf) across Y1 (crystal). A trimmer could be use instead of the fixed cap. What that will do is shift the frequency of the time base a little lower.
(This post was last modified: 02-25-2019, 05:48 PM by
Radioroslyn.)
Threads: 3
City: Chesapeake VA
Frequency wise, the AM25 is fully tunable, what the builder has to decide is what range of frequency to build the output matching network. You may need to rebuild the coils but that won't stop it from working on any frequency you select.
I've built one and are actually fairly good.
See page 18 of assembly manual.
Tom
