Philco K-1633 turntable,speakers in console restoration
Hello, I recently acquired a K-1633 model console with working turntable and I’m trying to figure out my best options to restore it. The speakers work when using the ab cables but I cannot get the turntable to work with the speakers. Does anyone have insight on this model? History, year, etc? That may help me with my next steps. I am having trouble finding information on this specific Model online. Thanks!
Hello and welcome. You might have a look here and see if this looks like what you have.
About the tenth post down is mentioned an K-1633x Philco console.
https://antiqueradios.com/forums/viewtop...1&t=180065
Hi and welcome,
Did find a little bit abt your set. It's from 1962. A K-1632 is listed in one service manual in another it list several other model including the '1632. Have a look here  http://www.rsp-italy.it/Electronics/Radi...n/1962.pdf  Go to page 91.
91H Code 126 Restore
There are currently 2637 online users. [Complete List]
» 2 Member(s) | 2635 Guest(s)
