07-19-2019, 09:29 PM
How do you test a 0A3 Tube.. Its not listed for my Hickok 600A
Skip
Skip
Tube from SG
Skip
07-19-2019, 10:48 PM
The 0A3 is a cold cathode voltage regulating tube. It operates a bit like a neon bulb, and will glow when in operation. You can check if it is working by measuring the voltage between pins 2 and 5 while it is in operation. The voltage shouyld be about 75 volts.
Here is a link to the data sheet: https://frank.pocnet.net/sheets/049/0/0A3.pdf
07-19-2019, 10:56 PM
It is same as Zener for solid state.
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
