Philco Repair Services
I just moved to El Paso Texas. I'm having trouble finding a local tech that specializes in Tube systems. Can anybody recommend where I cab ship my amp chassis to get restored?
What happened to Texasrocker?
He hasn't posted anything lately.
I do not remember what part of Texas he is in, but I would bet he would be willing to help you out.
Do a member search for "Texasrocker" and you should either find his email address, or be able to send him a PM via this Phorum.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
