Is Anyone going to be restoring a model 70 soon?
I think I read somewhere that the 370 was the first chairside Philco produced. I'm sure someone here can set me straight if this isn't true. I've got another one that as a model 91 chaiss Maybe a 91LZ?
I've got Rons book. I should look. Where the heck is that book anyways? 8)
tractorforum.com *** I reserve the right to be wrong
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
