Model 54 question
I've just started restoration of a Model 54. This model has a pushbutton "safety switch" that disconnects both sides of the AC line.
Why is this switch on this model? What was the reason for adding this switch?
I haven't seen this switch on any other Philco models.
Thank you, Don
So you don't get knock on your derriere when you have the back exposed.
Philco 49-1040
