Operating Philco 39-55
Is anyone aware of the existence of what would amount to an operating manual for the 39-55? I just acquired one, without the Mystery Controller, and I'm curious if the Controller is necessary to operate the unit. I haven't had the time, since acquiring the piece, to even see if it's in working order, but I plan to get started this weekend.
There is a post on this page right down from this one about your set . 39-55 adventure. Icon_biggrin
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2628 online users. [Complete List]
» 3 Member(s) | 2625 Guest(s)
