Bakelite block condensers
Rebuilding bakelite blocks and got one (4989E) with a resistor in it.
What type/wattage resistor will suffice?
Carbon?
Wirewound?
1/4 watt?
1/2 watt?
Thanks and have a good weekend
Tim
I think the answer is "yes, any of the above". What model is the radio for further verification of how it applies in the circuit?
-Bill
Hi Exray
Model 70 (early) inside the grandfather clock (570)
My diagram escapes me (in my mess) right now.
Block has a .09mf cap and a 250 ohm resistor.
Tim
I used a 1/2 watt 250 ohm in mine . Ihad three of the boogers never could figure what the resisters suppose to do .
Icon_rolleyes
Doing some quick math, a 1/4 watt is more than ample. Screen current of 1.7ma. P=I^2 x R (.0017 x .0017) x 250. = .0007 watts.
I don't understand why its in the circuit either? Maybe it helps prevent oscillations or something?
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
