Philco Model 52 Multi Cap Can
I'm restoring a Philco Model 52 Grandfather clock.  The model 52 radio used has a multiple capacitor can containing a .1, .15, .25 & 2 ea .5uf capacitors contained within.  Issue I have is the drawing shows
this component as capacitor 23.  On the drawing all 5 connection points do not indicate the capacitor values at those connections.  I don't know which value goes where......      Any in site would be greatly appreciated.
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
https://philcoradio.com/library/images/schem/51.jpg
Hope this helps
Mike, Thanks!  That is exactly what I need
Philco's
52GC                38-35B
