39-6CI
I pulled the chassie out of my 39-CI[also found 39-6CI on the bottom of the cabinet so it was originally painted] I was surprized to find it is not a AC/DC set ,it has a little power transformer with tube filaments not in series, and 215volt "B" voltage! seams to be a expensive way to build a cheap radio?
Yep, the 39-6 is an AC-only set with a transformer. Did you also notice that the wires coming out of that transformer are, like the rest of the wiring under the chassis, insulated with rubber? Icon_eek A disaster just waiting to happen.
Philco wised up in summer 1939 and went back to cloth-covered wires for their power transformers in the new 1940 models. Too bad they did not go back to cloth on the rest of the wiring.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5995 online users. [Complete List]
» 1 Member(s) | 5994 Guest(s)
