46-350 hinged back?
Have any of you seen a Philco 46-350 with a hinged back? This one is hardboard, so I suspect it is a nice-quality modification:
[Image: http://i269.photobucket.com/albums/jj77/...hinges.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
It seems like I have seen one like that in the past, but I am not sure. I've serviced a few for people, but have never owned one myself.
There are currently 9419 online users. [Complete List]
» 1 Member(s) | 9418 Guest(s)
