What did I buy?
http://cgi.ebay.com/130495289420
Can anybody tell me if it is a model 60MB or a 66B? Had a model 60MB years ago.
Tnx!
Impossible to tell from the photos. Good luck stripping the brown paint from that thing.
I thought that would be the answer. Couldn't be worst that that model 20 cabinet!!!
Tnx
Terry Hoping for a 66B
The shortwave dial on a 66 goes to 16.0 MHz, the 60 only goes to 4.0 MHz
Yeah I'm hoping it the 66 as it does better SW coverage. I've the 60 in a cathedral cabinet.
Hooray!!!!! It's a model 66B. Everything looks good but the dial escutcheon is worn off sanded maybe? Should be a fun project to get going again and cruise the SW band!
ps anybody got an escutcheon for 60mb or 66b?
