"Board attachment quota has been reached".
Okay....
Can't add pictures along with my latest post to show the work in progress.
Any suggestion to circumvent the limitations ?
Syl
I had a feeling this would happen eventually.
Syl, if you could please send the photos to me, I will post them for you.
mr.philco AT yahoo DOT com
Thanks.
Oh, I also increased the board attachment quota.
