Hello All New Guy From NY
Hi all
I am John, From NY, have a couple of Philco, and know a couple of people here from another forum, look foward to talking to and learning from others
John
Welcome, John.
Hello, John! Good to see you made it here!
Stand by, fellow Phorum members: John is unbelievably good at finding radios!!!!
There are currently 9255 online users. [Complete List]
» 1 Member(s) | 9254 Guest(s)
