Mystery Resistor
I'm hoping someone can assist me in identifying this resistor...there is no dot so I don't think it follows the body-tip-dot format. This resistor came out of a 40-190 and according to Ron's resistor page, it says that in the early 40s they changed to the modern stripe numbering scheme. The only pages I've seen though indicate that a resistor that starts with a silver band is not a valid color scheme. It could be grey I suppose.
Resistor measures 150 ohms on a voltmeter, and there are no 150 ohm resistors anywhere close on the schematic.
Dave
I think I figured it out...production changes indicate that in run 5 they added a resistor not shown on the diagram 33-115339 in series with the plates of the 6J8G tube (which was also a change that I see in my radio). Thanks to Ron's handy resistor translation page, this should be a 150 ohm resistor, 1/2 watt. It actually measured at 156 ohms, so pretty close to what it should be.
Dave
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8217 online users. [Complete List]
» 1 Member(s) | 8216 Guest(s)
