What resistor wattage?
I have my two PT-94's that I'm working over and there's a half dozen resistors that I'm going to replace. Do I have to calculate the wattage necessary or can I just use all two watt and be safe? How do I know what to use?
Alan
The factory parts list should list the Wattages, if it is a Philco Transitone, an AC/DC set, most of the resistors will be in half Watt sizes with maybe two or three two watt jobs. You can usually tell by the physical size, the smallest carbon resistors will be either 1/2 Watt or 1/4 Watt, use 1/2 Watts just to be safe, the larger sized ones will be either one or two Watts if they are carbon, each about double the size of the last.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4374 online users. [Complete List]
» 2 Member(s) | 4372 Guest(s)
