Looking for info on Philco sealed cap
Went to the "bench" and found the nice cross reference to cap values in the various sealed caps for my model 19. I have one that seems to be missing from the list! It's a 8035C. A four connector (linear) counting ground. Can anyone advise the cap values and hook up?
Thanks Jerry
Hi Jerry,
My copy of the "Philco Condensers & More" book shows the diagram of the # 8035-C as follows,
The small tapered end of the bakelight block is ground ( mounting screw end), the two other lugs have separate 110 pf caps going from each of them to the ground lug. It is a dual 110pf to ground capacitor. Hope this info helps, and good luck with your restoration! Icon_thumbup
Thank you Texasrocker. Appreciate your help.
Jerry
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 3801 online users. [Complete List]
» 4 Member(s) | 3797 Guest(s)
AvatarAvatarAvatarAvatar
