40-150 unusual chassis shims
When I pulled the chassis out of my 40-150 I found these two U shaped shims held in place with staples. I figured probably not factory except they are a perfect fit. I'm wondering what others may have found in a 40-150 or maybe some other model Philco?
Larry
Very interesting. My 40-150 has those, also. Don't know why, nor do I know the significance of these. ???
On the other hand, my 40-155 does not have these, neither did a 40-155 I used to own.
I noticed that even with the shims in the shafts are below center of the front holes. I suspect that if the shims weren't there and you tightened down the chassis bolts until they bottomed out the shafts might rub the bottom of the holes. I wonder if there is a slight difference between the 150 and 155 cabinet as far as the location of the shaft holes?
Larry
Have you replaced the rubber pieces on the corners of the chassis? I need to do that to mine, also. And as you said, without the new rubber cushions, the control shafts are still rather low (below center).
I have yet to restore the chassis in my 40-150, so I probably won't replace the rubber corner cushions until I work on the chassis.
The rubber corners are in good shape, which surprised me as I had already bought replacements. I think it may be due to the shims not allowing someone to tighten the chassis bolts until the rubber corners are squashed or cut.
Larry
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 2694 online users. [Complete List]
» 4 Member(s) | 2690 Guest(s)
AvatarAvatarAvatarAvatar
