Mystery Control labels
The labels on my Mystery Control looked pretty bad, so I decided to measure out and make a repro.
Scanned an original, measured it out, then used Paint Shop Pro to do the finishing touches.
I hereby donate an original. Print it at 18.5 mm for the length, and you'll have it.
The font you want to use is Alternate Gothic LT No. 2
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
The other pic...old vs new....
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Excellent job! Icon_thumbup
Now the question is: Where can we obtain the Alternate Gothic LT No. 2 font?
You can get it at myfonts.com
Thank you !!! My control badly needs some new labels Icon_smile
There are currently 8799 online users. [Complete List]
» 3 Member(s) | 8796 Guest(s)
