Another Philco
I have a great Brother-in-law He picked up this Philco 625-s for me last Sunday!
[Image: http://i1095.photobucket.com/albums/i474...ef1ec1.jpg]
[Image: http://i1095.photobucket.com/albums/i474...8c1e3e.jpg]
That's a lot of cabinet for a little bit of radio... Icon_wink
But seriously, congratulations! Icon_thumbup
Ty Ty Im running out of room! Icon_lol
Nice little set and pretty easy to work on too! Always like that 1936 style dial. Too bad there's no shadowgraph.
Nice set! If you are running out of room, get rid of the furniture!
Philco 91 Tuning Condenser
