42380 aerial transformer
gentlemen
I am fighting with this 42380 replaced the power transformer, output transformer, tubes, caps, wires etc...
now I find out the antenna trans is missing its coil. all other coils read OK. there is 0 ohms on all terminals and no sign of an existing coil !!! This coil is for the broadcast band and police band. the only info on the schematic is "single coil with 4 taps, 150 ohms total" nothing else shown. I can rewind this coil if I have the info, and determine if there is some kind of center core. I have tried to find a replacement coil (for days now) thru all the normal channels with no luck...any help would be appreicated.
Have you tried this site for coils. IF and antenna coils
http://tubesandmore.com/
The speaker table error?
Philco 70 antenna lead
