Philco 38-12 help
What are the voltages for the electros on this model I think they are 4 and 12mfd
you could use 350v units but 450v are easier to find.
Ok cool thanks I took a chance and ordered some 450 volt ones Guess my instincts were correct ty Doug
Never a problem to use higher voltage capacitors. Just be very sure polarity is correct when you replace them.
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8321 online users. [Complete List]
» 1 Member(s) | 8320 Guest(s)
