Edison Radio
Saw this Edison R7 radio on Ebay. Item 110879184375. Looks worthy of restoration if you are in the Louisville, Ky area.
Those early Edison/Victor sets can be a booger to work on. I still have recurrent dreams about an R32 I did 30 years ago.....
No bad looking....not an expert on prices, but 100 bucks is bearable.
It's alright if you really want one, but I wouldn't go out of my way to get it, other then the name it's another generic four legged console from the 1928-31 period. A radio in this sort of shape would be under $75 at a swap meet with the paper work, under $50 without, the finish is completely shot and flaking off. Most of the tubes appear to be later ST style replacements except for the Arctrus #27 tube, the set also originally had a back with a cloth in it, the frame is still there. You have to remember that even electrically restored and refinished it isn't worth $250, so the only reason to get it is because you like it, not for profit. One thing that will kill you on anything other then a local pickup is the shipping, in fact that's the number one thing that causes console sales to fall through.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8095 online users. [Complete List]
» 1 Member(s) | 8094 Guest(s)
