Philco 90 Operating Instructions
Ron,
Was going through my files and found a scan of the operating instructions for a Philco 90 (2 pages, 300 dpi). Says "Models 90, 90A and 90E". I e-mailed them to your account in case you want to add them to the download section of this site.
Regards,
Geoff
Thanks!
Philco 91 Tuning Condenser
