A Philco 118 Chassis
I have no idea why I decided I wanted this, but here it is. Maybe I am going to find a 118B cabinet and speaker????
[Image: http://i1185.photobucket.com/albums/z345...philco.jpg]
Gene
Nice knobs! If you want to make a Frankenradio I've got a 650 cab.
Maybe because the 118 is a pretty good radio! I can not recall ANY 118 that I had not being an excellent receiver.
Terry,
Is your cabinet a table model?
Gene
Hmmm... not sure the 118 control shafts will fit in the model 650 holes.
Mike: if you're reading what I just wrote, don't (heh heh heh) go there....
There are currently 10616 online users. [Complete List]
» 3 Member(s) | 10613 Guest(s)
