Philco 91RX field coil.
Hello,
I an helping a friend restore his Philco 91RX code 122 and I need to know the value of the field coil resistance. I can't find it anywhere on the service sheets.
Thanks in advance.
Stuart
The RX should have two speakers in the remote cabinet, an H7 and a K12.
H7 field coil is 3275 ohms
K12 field coil is 3275 ohms.
Hello Mr Forbes,
Thank you very much for that.
Regards,
Stuart
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
