Shadow meter, probably the early version
So, as I have already described it in my Philco 18 thread, the coil in the meter seems open.
I want to remove it. Although here
http://www.philcorepairbench.com/tips/svctip01.htm
it is described how to service the early version, in mine there is no screw, and the coil is held with its core ends spread.
Here it is:
Now I need to remove it. What's the best way?
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
