Coil over tubular capacitor
One thing I've noticed Philco doing is winding a coil over a tubular capacitor. I've seen it in the 46-350 (L1/C26) and also in the 48-475 (no coil #/C317). Perhaps this is done in other models as well. Question is: How critical is this combination, i.e., does the cap act only as a form for the coil, or is the design such that it relies on the proximity of the coil to the ground shield of the cap? If the latter, is there a secret to recapping this combination?
Hi
This cap-coil combination was used in many Philco receivers, chiefly right after the war. It serves as an IF trap in the B- circuit. Chuck has an extensive write-up on this subject on his website:
http://www.philcorepairbench.com/tips/svctip37.htm
In practice, you can usually eliminate the cap-coil combo by replacing the capacitor itself, leaving out the coil, with no ill effects. However, you may retain the coil if you wish.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
