Crosley 148 tube ?
Question on the tubes on this radio?
looking at the #57 tube
Trying to trace wiring and want to number the print with the proper pin numbers on the tubes figured out the cathode(5), heater(1,6) and the plate(2) (which is the rectangle on the right of each tube?) but the other three got me is the screen grid always in the middle? I see on some tube prints they are labled G1,2,3. Any help would be appreciated.
Eric
Screen Grid ?
Supp Grid ?
Bias ?
http://www.nostalgiaair.org/PagesByModel...003276.pdf
1 Heater
2 plate
3 g2 or screen grid
4 g3 or suppressor grid
5 cathode
6 heater
Never heard of the bias connection on a tube socket.
Thanks for helping I should have been more clear in what I was looking for but that is the life of a novice. Referencing the print for the Crosley 148 the 57 tube. Starting from the left on the diagram
The first is that the grid cap going to the tuning cap and coil?
Then the next is the cathode 5
Then the 2 heater leads then 1&6
Then screen grid 3?
Then suppressor grid 4?
and lastly the plate 2
Just trying to understand what is going on
Eric
Perhaps this will help. I'm thinking that you don't know what the symbols mean??
http://en.wikipedia.org/wiki/Vacuum_tube
Scroll down and you will see a diagram of several types of tubes.
Got the symbols let me see if I can refine what I'm looking for.
On this print it is not clear what grid is what to me. There are three grids showing on data sheets they show them stacked and labeled G1,2,3 with pin numbers this print doesn't show that. Is G3 always next to the plate? I the grid on the left the grid cap? So when it asks me the voltage on the screen grid which one do I go to? I guess I'm asking on this print how can I tell which is G1, G2, G3. Can you point me to some more reading material and thanks fo the help.
Eric
Well typically G1 is the control and is connected to the cap This only applies to receiving tubes. Transmitting tubes usually have the PLATE connected to cap. G2 is the screen grid the middle grid. G3 is the suppressor grid closest to the plate.
Thanks Terry,
That is what I was looking for, trying to number the print with the pin numbers so I can trace the wiring I had the tube data and pin numbers but the layout on the old print thru me G1,2,3 is confusing enough at this point I needed (wanted) to know which grid was which. Also found today Cunningham Radiotron book online in pdf http://www.tubebooks.org/tubedata/RC12.pdf
Which went with what you said when I looked up the 58 tube it had a nice diagram on page 110.
Thanks again now the real work starts somebody made a lot of changes I will probably be back trying to figure out what I did wrong
Eric
39-7 Magnetic Tuning Vernier Issue...
Howard, First thing you can do is to soak this unit in some lacquer thinner . What happens is the old greese gums up ...radiorich — 01:23 AM
Hello Howard, I wanted to welcom you to the forum and you have come to the right place to get some help with you Tuning...radiorich — 01:16 AM
First of all, this is not a restoration.  This radio has been in constant use for as long as anyone in my family can rem...HowardWoodard — 12:14 AM
philco 91 detector transformer
hello i have a bad detector coil and i was wondering dose any one know how many turns and witch lugs aare used and size ...mg34.42 — 11:55 PM
I have never hear of the Suppressor Grid to be used in parallel with the Grid. SG sole purpose is to be anti-dynatron g...morzh — 11:03 PM
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
