Philco 76 resistor values
I have obtained a beautiful Philco 76 highboy console radio. The schematics I find do not show the values of the 5 wire wound resistors - there are 2 gray colored resistors with a yellow tip, 1 white resistor,1 yellow resistor and a green resistor. Does anyone know the value of these 5 resistors? Thanks, Phil
Look here:
http://www.philcoradio.com/tech/images/76.jpg
Ron: Thanks, Phil
Philco 91 Tuning Condenser
There are currently 6901 online users. [Complete List]
» 1 Member(s) | 6900 Guest(s)
