Model Philco 37-10 Year & Light Bulbs
What year is my Model 37-10 Stand up Philco Radio.
Also where can I get the G-E 47 Bulbs. Need 5 or 6 Can't remember. Found Tubes OK From Antique Electronic Supply @ 480-820-5411
Thanks Ron AKA SoCal-Poor-Boy. Mis CA. MN. is Cold and 50% Higher Cost of Living than CA??? . Icon_wave
OH Pic. of other Baby...
Well your 37-10 is a 1937 model. I assume the 47 you refer to is a dial lamp?! Should be able to find them the same place you found tubes--AES. Other suppliers have them too.
http://www.tubesandmore.com/products/P-47 or http://www.radiodaze.com/category/60.aspx or others.
Philco 91 Tuning Condenser
There are currently 9283 online users. [Complete List]
» 1 Member(s) | 9282 Guest(s)
