philco electrolytic cap part number help
Hi Guys Im working on a 37-610 and it has 3 electrolytics here are the part numbers 30-2118 30-2026A and 30-2117S I think 30-2118 is 16mf but im not sure about the other 2 can anyone help? Thanks Doug
I take it you don't have the service info?
30-2118 - 16 uF
30-2026 - 8 uF
30-2117 - 12 uF
Thanks Ron no service info yet Gonna try now Thanks Again Doug
I suggest we stick to some known ways of denoting the multipliers.
For example "m" is always ""milli" which is 1/1000-th whereas "u" (imitates greec "mu") stands for "micro" which is 1/1000,000-th.
One mF is a whopping 1,000 microfarads.
It is, after all, engineering that we are dealing with here and accuracy is important.
Tried downloading the service data(pdf files) and it keeps saying error downloading pdf files....
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2963 online users. [Complete List]
» 4 Member(s) | 2959 Guest(s)
AvatarAvatarAvatarAvatar
