European radio schematics
Found this German site that has some of the hard to find German radio schematics.
http://www.nvhr.nl/gfgf/schema.asp?Zoeke...mitted=yes
this is a better link.
Best regards, Paul
Thanks for the link! Icon_thumbup
And if you take it a step further, searching for "Philco" yields this results page:
Thanks Ron , It didn't even occur to me to try American Radio's. That great.
I was able to get 600 dpi scans of the Grundig, I just purchased, emailed to me. Chassis layout, alignment and schematic. You can also have them mailed. This is a private individual he does ask for a donation to keep his service running.
http://home.arcor.de/walter.groer/schema.htm
Roy
