Michael Feinstein American Songbook
Watch the new episode S3 episode 3, I promise you will thoroughly
enjoy.....opens with an array of various Catalins starting with a variant of my Mom's...(now my) GE L570, Fada's, Emerson's and Motorola's. Later RCA's Zenith's and Bing Crosby doing a Philco ad.
Lots of NBC and CBS Radio shows and unbelievable collections of microphones and other early broadcast equipment and memorabilia
This series is a National treasure.
Why lately do I have to sign in constantly every time I want to post, this is just a recent problem.....anybody???
Loved that episode. Not just for the radios but also for the transcription discs and acetates.
chris25260880 Wrote:Why lately do I have to sign in constantly every time I want to post, this is just a recent problem.....anybody???
Clear your browser cache, and try again. If you have your browser set to delete cookies when you close it, then you will have to sign in every time. Our cookies are safe, they do not track you...and they are delicious, too. Mmmm, chocolate chips and butterscotch chips. Icon_smile
There are currently 9836 online users. [Complete List]
» 1 Member(s) | 9835 Guest(s)
