Philco 76 capacitor value
I have a Philco 76.....one of the capacitors has a part number of 3082. Does any one know its value? Thanks, Phil
Philip,
3082 is item 18 on this schematic and is listed as 250uuf:
http://philcoradio.com/tech/images/76.jpg
Carl
Northern Panhandle, WV
Carl: Thanks.....would you happen top know what part number 3897A's value is, for the same radio - Philco 76?? Phil
Item 21 on the same schematic listed as .01uf.
Carl
Recently purchased a Philco 76. I've been able to identify all the caps except for:
C9 3892-A
C13 3584-B
C21 3897-A
How do I get the values for these caps?
Thanks, Paul
The speaker table error?
Philco 70 antenna lead
