My Zenith 8-S-661
I found this radio at a church rummage sale a couple weeks back for $50, which is cheap for a Zenith in good shape. Had it gone through and it is a good performer with the push-pull 6F6 tubes and really sucks in he stations. Icon_smile I also like the clean lines of the cabinet.
Nice find, Jay!
yeah. Whatever they say about Zeniths, they are lookers.
I like'em.
Icon_thumbup Looks great!
There are currently 7227 online users. [Complete List]
» 1 Member(s) | 7226 Guest(s)
