Help on id a new to me philco!
So my wife and I have been looking for an older record player and came across one today we couldn't pass up. What i have gotten off my hours of research is that i have a add on tuner that is model number rt-300 and on the tag it has tp8-089. That number in my google'ing has got me no where, it needs a needle trying to nail down what it is to get the right one. Got it home cleaned out the spider webs and fired it up. Radio works great just need a needle. The lid it says philco stereophonic high fidelity.
Thanks in advance and awesome site!!!
[Image: http://img.photobucket.com/albums/v485/V...73092d.jpg]
[Image: http://img.photobucket.com/albums/v485/V...f87162.jpg]
[Image: http://img.photobucket.com/albums/v485/V...9f975c.jpg]
That reeks 60s.....clearly not a pre-war.
Yeah we didn't figure it was old old but 60's is ok with us. I finally figured out the needle just be nice to nail down other info on it.
There are currently 7602 online users. [Complete List]
» 1 Member(s) | 7601 Guest(s)
