New 40-180
Just picked it up over the weekend. Overpaid but it went to a good cause. A single father and his son who has autism. Plays ok, needs some antenna and wood work. My mystery control and Lightening Arrestor in original box with hardware and instructions sitting on top. Goes great with my 40-190 with the can and bottle of furniture polish and refrigerator cleaner and polish
Philco 91 Tuning Condenser
There are currently 9324 online users. [Complete List]
» 1 Member(s) | 9323 Guest(s)
