42-PT-91 Dial cord
Last week I acquired a 42-PT-91 for $30. All caps and tubes are original.
When I took it apart I realized that the dial cord broke in two pieces and need to be re-strung.
I have spent close to 12 hours looking for diagrams and trying to re-string it on my own before I get into replacing caps and polishing a cabinet.
I looked at probably a dozen of places but can't find a string diagram for this radio Icon_sad
Perhaps someone has a diagram or has the very radio and can take pictures of how the cord is positioned.
Thanks in advance.
-G
My list of string diagrams doesn't include the PT-91. Nor can I find a picture of it on the Philco Radio Gallery. Is it a portable, like the PT-88? I have a 41-81T, which looks similar to the PT-88, and has the knobs in the same place. If there is any similarity I'd be glad to open it up and take a look at the dial string.
If your PT-91 is very different from the 41-81T, then obviously my suggestion won't work.
Alternatively, you could ask Chuck Schwark if he has a Philco service package for this model. It will almost certainly include a string diagram. Chuck charges a small fee for these documents, but they are well worth it. http://www.philcorepairbench.com/schematics.htm
John Honeycutt
Thank you for your reply. I shall try ordering a service package for this radio.
Though it is not a large radio, I do not believe it is portable. I think that if it was portable it would not have a power cord attach, though I am new to this and might very well be wrong. Icon_lol
Also seems that the knobs on mine are positioned differently from yours.
On an unrelated note 42-PT-91 looks very similar to 48-200, though my eyes might be failing me Icon_mrgreen
Thanks!
-G
42-PT91:
http://www.philcoradio.com/gallery/1942a.htm#bm
Obviously, it isn't a portable radio although it is rather small.
The 46-200 is identical in appearance:
http://www.philcoradio.com/gallery/1946a.htm#d
and the 48-200 is similar, but the dial scale is different:
http://www.philcoradio.com/gallery/1948a.htm#d
Thank you!.
I think I have figured how to re-string it successfullyIcon_biggrin. Let's see how long it lasts Icon_crazy
There are currently 11328 online users. [Complete List]
» 2 Member(s) | 11326 Guest(s)
