any one know name of this radio
[Image: http://i1303.photobucket.com/albums/ag14...620e0d.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...a82601.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...0a11c0.jpg]
any way to fine out who the maker is ?
thanks sam
i hope this is right if not sorry ron
Looks like someone threw it down a set of stairs, then stuck the guts into a different cabinet. For some reason the cabinet reminds me of a Stewart-Warner, but the close up photos may be a little too close up, though. I've seen some small plain RCA Victors that look similar, but perhaps some better pictures would be warranted.
