Restuffing Mershon caps
I have two pristine Mershon caps that I want to restuff. My question is: How do I take the tops off the cans without making the cap look like it's been mangled? I'm aware that I can Dremel the tops off, and resolder them when the restuff is finished, but I would rather not do this, since these caps are still shiny and totally unmolested.
Thanks in advance.
Try this. Should help.
http://www.philcorepairbench.com/tips/svctip45.htm
Model 27-84 BUZZ?Humm?
Hello Bruce, First all do mean a 37-84b ? Did you take any before and after pictures ?radiorich — 01:59 AM
Philco 630csx power cord
There are currently 3741 online users. [Complete List]
» 1 Member(s) | 3740 Guest(s)
