Fada 46
Well, finally off to check out a Fada 46, only a 500 mile round trip but will take a couple of days, staying in Laughlin (really cheap rooms and free food to boot). The radio is in Las Vegas, a short hop. Just hoping for some good iron and really hoping for no bad pot metal. Wish me luck!
Jerry
Good luck Jerry... remember - what happens in Vegas, stays in Vegas...Icon_lol
There are currently 10222 online users. [Complete List]
» 1 Member(s) | 10221 Guest(s)
