Newbie
Hi..My name is Mike...I live in eastern North Carolina and have recently acquired a Philco 47-1230 !...Excellent shape...It has a D-10A phono...Here's the trouble...The plastic gear is stripped that drives the cam...I'm sure this is a common problem...actually I did it because not knowing any better I turned the spindle by hand to get things moving...Well there went the gear!...I have since taken things apart and cleaned all the old hardened grease off and used 3-in-one oil to make things move nice and smoothly.
My question is...Where can I get a replacement gear?..Thanks for all Your help!...I look forward to talking to the experts!...Any advice You Guys can offer would be greatly appreciated....Thanks again!....Mike
Picture of problem will help. Someone here will be able to encourage/discourage/help you.
We were all new to this hobby once, suggest you change your sign in name to apprentice or whatever.
Thanks...I'll see if I can get a pic up this weekend.....Mike
Cannot get My camera to work...but thanks anyway...I made a gear Myself since No One could help.
Glad you solved your problem. If you post how you made the gear it might help someone in the future.
I simply machined one from aluminum.
Simply put.... Icon_surprised
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3379 online users. [Complete List]
» 1 Member(s) | 3378 Guest(s)
