Philco 024 RF signal generator
Being new to the forum, or should I say Phorum, this appeared to be the closest index selection to post my new thread. I have recently acquired a Philco model 024 signal generator. It would be helpful to find a source to obtain a schematic of this model. Any help would be greatly appreciated! I identified this model number from simply viewing the oldest pictures of Philco RF signal generators since this is an unidentified unit.
Carl
Hi,
Ask Chuck, he might have it.
http://www.philcorepairbench.com/schematics.htm
P.S. Welcome! Icon_smile
I do have just a schematic in my archives. No alignment info, some parts annotated. Uses a single 30 tube in a simple osc. circuit.
Could be aligned to dial markings with a freq counter.
Chuck
There are currently 9592 online users. [Complete List]
» 1 Member(s) | 9591 Guest(s)
